COOLANT LEAKING OUT SIDE OF THE HEAD AND BLOCK???
Cranked new engine up for first time with thermostat and fans finally kicked on, turned engine off after about 5-6 mins of running. Noticed coolant all along the bottom side of the head around the cylinder block there was wet coolant all along the block. Slow leak but enough to leave a small puddle on the ground.
Has anyone ever seen this? I thought coolant would just mix with the oil if its a blown head gasket or something. Very worried.. I drain the oil tomorrow!
Car: 1988 Camaro
Re: COOLANT LEAKING OUT SIDE OF THE HEAD AND BLOCK???
Could be the coolant sensor holes leaking. Each head has a hole drilled and tapped on the side for you to put temp sending unit, fan controller, etc if not used you put a pipe plug in hole.
Your plug or sender could be leaking
Car: 87 IROC
Engine: L31 350
Axle/Gears: 4.10 D44
The head bolts go into the coolant jacket. Was sealant used on all of the head bolts?
1 Post
Car: 1989 IROC G92 LB9 MK6
Engine: LB9
Transmission: MK6
Axle/Gears: 3.45
Looking for non-headgasket issues, you could have a leaking freeze plug as well.
Received 1,857 Likes
If you didn't, you have 34 little coolant leaks; 16 of them let coolant dribble down the side of the block, the other 18 let coolant into the crankcase where it will RAPIDLY DESTROY the oil and EAT the bearings.
I'm actually really hoping it is this.. I could see how with the fans blowing it would make it run towards the end of the block like it is. I did rub my finger on the bottom of the plug and it did have residue if coolant so well see.
I did coat the threads with thread sealant that's for sure.
