Which way LS1 water pump turns???
I need help. I recently swapped my engine on my 86 z28, it started to my surprise first time I turned key. However I have no water flow. Not sure if pump is turning the right way,if i put belt on wrong or thermostat is bad or just plain n simple pump is bad. Can anybody help? Don't want to go spend 240 on a new pump and then that's not it.How do I check for this kind of thing. Radiator is brand new
Ozzie
Ozzie
Car: 2012 F350 lariot/1991 Camaro RS
Engine: Powerstroke/6.0
Transmission: 6R100/4L80e
Axle/Gears: 3.73/3.42
Re: Which way LS1 water pump turns???
get a funnel and pull the top rad hose and pour fluid in holding it up to "prime the block" fluid pumps usually dont pull a vacum if there is no fluid in it so it wont pull from the radiator then it will take a few min of running to start ciculating leave the cap off at first then it will go down
the block will take about a little bit more than a gallon
Rarely do those pumps go bad and when they do its leaks not pump failure
Car: 86 Camaro
Engine: 355- hopefully a 5.3 this summer
it turns the opposite direction as the crank- so the flat part of the belt will be against the pulley with the ribs out.
Hello guys
I wanted to tell ya thanks for your response. I didn't know to prime block first and did not know which way pump was supposed to turn. I changed thermostat as well and it's all good now,Thanks again guys
evilstuie
01-09-2020 08:29 PM
eightsixseven
08-14-2015 03:09 PM
Zachattack0925
08-12-2015 09:52 PM
Street Lethal
08-12-2015 11:33 AM
