Thermostat Housing Bolt - Factory or Bad Joke by Previous Owner
Car: 1991 Firebird Formula
Transmission: 700R4 to WC T5 swap
Axle/Gears: 2.73 drum to 3.73 PBR swap
Not sure it's called a thermostat housing, but anyhow...
This is a bolt that has a nut half-way. (Threads above and below the nut that turn with the nut). When I try to back it out the top of the bolt hits a (coolant pipe?) directly above it.
It kinda appears the intake has been removed and replaced once, and I wonder if the previous owner put a wrong bolt on it before replacing the intake.
It been a while since I took the engine out so I can't remember if that kind of bolt served a second purpose as a mount of some sort, but I kinda doubt it. Never heard of removing the intake to change the thermostat....
Engine: 4++,350 & 305 CIs
Re: Thermostat Housing Bolt - Factory or Bad Joke by Previous Owner
Thats factory correct. Removing the T-body is the best way to get at that bolt.
Car: 1989 Iroc-z
Transmission: Auto 700R4
Axle/Gears: 9 bolt - 2.77
What ttop350 is correct. That's a factory bolt. Removing the TB will help but if you don't want to do that, remove the other bolt from the housing and then start removing that bolt. Once its loose, you can lift up on the housing and begin to remove the bolt all the way.
1992 Trans Am
05-10-2023 08:19 PM
eightsixseven
08-14-2015 04:09 PM
