Where to get radiator mounting pads?
Car: 92 Z28 Camaro
Engine: Procharged 406.
Axle/Gears: Moser 9" 4.11 Gears
I have a new custom Be Cool radiator on its way and I have lost the 4 rubber
mounting pads. Where could I find these?
Re: Where to get radiator mounting pads?
http://pwdstore.com/product_info.php...e1eca2dea5375a
If you can use the stock set for that radiator - Dave Clee carries them.
Car: 88 IROC Z/28-under re-construction
Engine: 5.7 Tuned Port
Transmission: It's in there....
Axle/Gears: 9 bolt Borg-Warner
i have a spare used set
Car: 92 Z28 Camaro
Shipping $$...from dallas to you... PPal mjdavis68@yahoo.com and i'll send them asap
mike
mike
Car: 90 IROC 2-92 Zs blk vert & prpl
Engine: stealth ram brodix track 1 ful port
Transmission: 700r4 4l80e
Axle/Gears: iroc 375 lokr 92 Z 277 pos vert 327
I have be cools in all my third gens; you will love them. Best rads IMHO. In the places where the rad comes close to other things and could rub I always line it with some silicone just in case.
I've found wide thick rubber tape available at Home Depot to work well for padding all the potential contact points between the radiator and the chassis. Comes in 1 inch wide rolls about 1/16 inch thick in the electrical section. I used this to isolate my Ron Davis radiator from the chassis rail by lining the entire rail and then using the stock pads with some trimming.
I have a Ron Davis radiator in mine !
I used the foam padding that is sticky on one side used to insulate refrigeration pipes in buildings.
Well it is in the uk anyway !
Worked perfect !
Worked perfect !
Car: 86 Camaro
Engine: 355- hopefully a 5.3 this summer
junkyard... look under the hoods of pickups if you have a beefier than stock radiator..
Hotrodboba400
12-10-2019 07:07 PM
Bohemian
08-15-2017 05:11 PM
IROCZDAVE (88-L98)
09-02-2015 08:49 AM
