Camaro running too COOL! why?
Car: 1990 RS Camaro
Engine: 305 c.i. v8 tbi all stock
Transmission: 700r4 bone stock
I know how the sounds, on of these thirdgens running too cool but its true. The highest it reached was the first mark on the temp gauge. i opened the hood and check everything with a temp gun and even after over an hour of driving you could touch the radiator cap and hold your hand on it. the exhaust pipes werent even hot. about a month ago i changed the radiator and thermostat and never had this issue it was running at a good temp. Now i know it got colder out, it was about 55*F here in jersey and even though it cooled down i really dont think the engine should run that cold. Let me know what you guys think any and all help is greatly appreciated. Thanks!
Car: 1990 RS Camaro
Re: Camaro running too COOL! why?
and to add to this madness, i have a minor coolant leak. go figure. haha im just lost... oh and also the check engine light comes on when i make a stop. this used to happen alot but only started back up again tonight. its a 1990 camaro 305 tbi all stock
Car: 1990 RS Camaro
yea i was going to start by changing it again and hopefully thats all it is.
1 Post
Car: 91 firebird Formula 350
Transmission: N/A, working on a t5 swap
Axle/Gears: 3.73 posi
sounds good. make sure you let everyone know what you find out. I've noticed on these forums not many people actually post when they solve their problem. that would be extremely helpful to anyone else who has the same problem to see what works and what doesn't.
Car: 1990 RS Camaro
yea absolutley thank you again for the help. I dont know if ill be able to get to a parts store until tomorrow but i will keep you posted. im almost sure itll be the thermostat
1 Post
hey, about that check engine light too. what code is it giving you? it's usually a good idea to take care of something that causes the check engine light to come on.
Car: 89 Black IROC-Z convertible
Engine: 305 TBI
Sounds like a combination of the cooler outside temps, new radiator and a stuck thermostat.
