Classic Industries all metal replacement radiator
Car: 1988 Firebird Formula
Transmission: 5 Speed
Need a new radiator, the original rad has leak on the recovery composite tank side of the radiator.
Anybody tried these steel OE style replacements from classic, how was the fitment?
I like the idea of metal tanks instead of the composite plastic on the original rad.
http://www.classicindustries.com/cam...crd18613s.html
Re: Classic Industries all metal replacement radiator
Are you interested in maintaining an original look? If not, you could have a full aluminum radiator for that price.
I just picked up a plastic/aluminum replacement from Vistapro for my car. It seems to be a good replacement so far, and appears original unless you really scrutinize it.
Car: 89 IROC Z28
Engine: 357 TPI
Axle/Gears: 3.42 Posi
I got this one a couple of years ago when I upgraded my 305 to 355 and it has been great so.
http://www.ebay.com/itm/3-Row-1982-1...294f00&vxp=mtr
It bolts right in with no modding needed. There are several stores on eBay selling it, I got my locally from some selling them out of his garage. Highly recommend it, all aluminum no plastic. They raised the price ~$20 since I got mine and I was to pick it up locally and saved the shipping cost.
Car: 89 IROC Z28
Engine: 357 TPI
Yes, the fans. shroud. and top mounting plate were able to fit perfectly with radiator. It is an exact replica of the stock except it was aluminum and a 3 row core.
Car: 90 IROC 2-92 Zs blk vert & prpl
Engine: stealth ram brodix track 1 ful port
Transmission: 700r4 4l80e
Axle/Gears: iroc 375 lokr 92 Z 277 pos vert 327
Aluminum dissapates heat better than copper or especially steel. The more rows and bigger (wider) rows helps as well (more area). I called be cool about four years ago and they would custom build me a new rad with two 1 1/4 tubes for not much more than a regular new one. Can you imagine how good two rows of 1 1/4 would cool. Thats 2 and a half inches of cooling area or 25% more.
Guest
Posts: n/a
1992 Trans Am
05-10-2023 08:19 PM
