A/C delete, cooling fan on all the time
1 Post
Car: 1986 sports coupe, 1984 F41
Engine: 3.8L Turbo SFI, stock 305
Transmission: 700 R4, 700 R4
Axle/Gears: 3.42:1, 3.08:1
Hey everyone, I have deleted my A/C, and now my cooling fan runs all the time. Is there anything I can do to stop this? I imagine it has something to do with the A/C pressure switch being disconected. Could I just jumper the pressure switch wiring to "trick" the car into thinking the A/C is turned off?
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Cheap Trick
Also, why is it still in the car?
Anyway the wire that goes to the Pressure Switch probably became inadvertently grounded during the deletion.
Remove that wire.
Happy Racing!
8 Wheels Corner Better Than 4, If You’re On The Outside You Have Fair Warning
Car: 1986 Z28
Engine: 383 TPI
Axle/Gears: 4.10
Re: A/C delete, cooling fan on all the time
Were you able to solve your fan problem? I am experiencing the same problem because I removed my a/c as well and I'm looking for a solution.
