Connector For a/c Heater Box
Car: 1987 Trans Am GTA
Engine: TPI 350
Axle/Gears: 9 bolt From An Aussie
So I drove the firebird for the first time today in cooler wet weather. Well I thought it still had the defrost hooked up but I got home and seen the wiring to the a/c box under the hood had been cut. Wires are still there but no connector. Not sure how to search for it or even if it will be the right connector. Anyone have a pic of the connector or where I can get one? Autozone has one that looks similar but its $20? Seems a bit high!
http://www.autozone.com/autozone/par...er=349718_0_0_
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
Re: Connector For a/c Heater Box
doesnt look right to me. is it the plug for the blower motor, or the ac controls on the box? the blower motor lpug should just be 2 prongs. the ac controls should be a 4 prong, but its not just 4 prongs in a row, it has one prong offset. best bet would be a junk yard.
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
'87 plug at resistors. You can use female spade plugs to get by for a temp fix.
86CamaroDan
09-29-2015 10:08 PM
