Will this work instead of rubber isolators?
Old 10-20-2011 | 07:43 PM
THETANK's Avatar
Car: 91 rs
Engine: Carbed 355 CR 9:1 xr276 cam
Transmission: 700r4 2600 stall
I installed a new radiator and had to remove the rubber Isolators. I was going to use a bike inner tube as some have, however when they were I placed them under the radiator they seemed so thin that they were almost ineffective. I then got the idea of using spray foam under the radiator and was wondering if that would be more effective. I am also concerned how it will hold up to heat.
I ended up pulling the bike tubes out and now it is sitting on the metal and feels more snug then with the tubes.
My car is not a DD and sees maybe 1000 miles a year.
http://www.evercoat.com/productDetail.aspx?pID=24
Something like this
Old 10-20-2011 | 08:50 PM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
Re: Will this work instead of rubber isolators?
why cant you use the rubber isolators? im using the stock ones on my alum rad. i just had to trim the front piece that curves up since the rad is thicker than stock.
Old 10-20-2011 | 10:07 PM
THETANK's Avatar
Car: 91 rs
I maybe able to use the stock ones but I would have to trim them way down, because it sits up about 1 inch too high.
Old 10-21-2011 | 04:24 AM
travis401's Avatar
Car: 91 Camaro RS
i pretty much cut the whole front L shape off. so its not just a flat rubber isolator and it works fine.
Old 10-21-2011 | 06:19 AM
redneckjoe's Avatar
Car: 87 iroc-z
Engine: 454
Transmission: th350
i agree, try & use the isolators. you definetly dont want an aluminum radiator to touch any metal because you can get small amounts of voltage in the metal, promoting electrolosis. if you have to mount it metal to metal, jegs sells sacrificial anodes that screw in where your drain petcock is.
Old 10-21-2011 | 06:55 AM
THETANK's Avatar
Car: 91 rs
I will use the rubber isolator / tire inner tube. I was just thinking ( I know thats dangerous) foam would be an alternative and maybe better but Ithink i'll stick with what is tried and true.
1992 Trans Am
05-10-2023 08:19 PM
customblackbird
08-15-2021 11:16 PM
1992rs/ss
05-19-2020 08:02 PM
1992rs/ss
16
01-28-2016 10:58 PM
db057
08-22-2015 09:17 PM
