Electric fan hitting radiator? What stops it? Help!
Old 10-19-2011 | 02:34 PM
Thirdgenlove's Avatar
Car: 1989 Trans Am GTA
Engine: 350 Tpi rebuilt
Ok so most people have electric fans but I never see people having issues with them hitting the radiator and rubbing them till it causes a hole ...twice.... So Im on my third radiator And I'm wondering if anyone has pictures of what keeps the bottom of the fan from rubbing on the radiator. I can post a picture of mine later
Old 10-19-2011 | 03:17 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Re: Electric fan hitting radiator? What stops it? Help!
There's a lower fan bracket that the frame around the fan attaches to that may be missing. It's black plastic, about 18" or so and and holds it in place. Two different ones, depends on whether you have a single or dual fan system
Old 10-19-2011 | 04:50 PM
Single fan, inwill have to hit the junk yard or my brothers car to see if he has it. Could of saved myself some cash had I known that
Old 10-19-2011 | 08:37 PM
Thirdgen89GTA's Avatar
Transmission: M28 T56
It should be on just about any thirdgen you find in a junkyard. Even if its a single fan you can always drill the holes for the dual fans.
OR!!
You can yank the dual fans out of any LS1/LT1 car and retromod those to fit and have a real shroud for better cooling.
Old 10-24-2011 | 12:54 AM
iinversion's Avatar
Car: 1987 IROC-Z (G92)
Transmission: M5
I have dual fans on my 1987 IROC and I ran into that problem today. Well short story is my fans haven't been working so I hooked them up to a toggle & they both were rubbing up against the radiator because the brackets as already mentioned.. are plastic and they were all broken. I just did a quick fix and zip tied them back a little from the bottom.
Old 11-01-2011 | 05:47 PM
1roc89z28's Avatar
is it overheating?
83 Crossfire TA
01-03-2016 02:26 PM
IROCZDAVE (88-L98)
09-02-2015 09:49 AM
IROCZDAVE (88-L98)
09-02-2015 09:43 AM
Fox118
09-01-2015 05:07 PM
eightsixseven
08-14-2015 04:09 PM
