takes awhile to get heat
Car: 91 formula
Engine: 350 tpi
Transmission: auto
Axle/Gears: poss
i just changed heater core yesday and thermostat. but why is it taking so long to get warm. and its full of antifreeze.
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: takes awhile to get heat
What temp stat did you use? You'll hardly feel no heat with a 160, very little with a 180, and "normal" heat with a 195.
Car: 1984 camaro Z28
Engine: 355 SBC
Transmission: 700 r-4
Axle/Gears: Strange 3:73 posi
with a 160 you'll get next to no heat , I would block half my radiator in my s-10 that had a 160 in it and it would get good heat.
Car: 91 formula
Engine: 350 tpi
Transmission: auto
Axle/Gears: poss
well switched it out with a 195 same thing . what temp my fan spose to kick on at? cuz it comes on at about 130 deg.
Car: 91 formula
Engine: 350 tpi
Transmission: auto
Axle/Gears: poss
found out im getn no vacuum to diverter valve. now what do i do?
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
the diverter valve shuts flow off to the heater core when you set the ac to max. no vacuum means water will always flow into the heater core.
Hotrodboba400
12-10-2019 07:07 PM
