fan switch not working??
Old 07-19-2011 | 06:40 PM
Stevolwevol's Avatar
Car: 86 IROC Z, 92 RS
Engine: 305 4bbl, 305 TBI
I have the green w/white stripe grounded so I can turn the fan on when I want to. I left the switch off while idling, and it was getting too warm, and the fan wouldn't come on till I turned it on w/the switch. Could the fan switch be bad? Would the fan come on w/ground switch if the fan switch was bad?
Any input would be appreciated.
Old 07-20-2011 | 11:56 AM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Re: fan switch not working??
Those fan switches are famous for short lives , and as long as you provide a ground through either the fan switch OR your manual switch to the relay, the fan should go on
Old 07-20-2011 | 12:45 PM
I remember now when I blew a relay the fan didn't come on when I grounded the green/whit stripe wire. It didn't occur to me till after I posted the thread. So grounding the switch is the same a bypassing it?
Old 07-20-2011 | 12:59 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Yeah, All the fan switch does when it reaches it's temperature is ground the wire
Old 07-20-2011 | 01:12 PM
Makes sense.
RazorN8
01-07-2022 11:44 AM
The_Phoenix
02-04-2016 07:10 AM
eightsixseven
08-14-2015 03:09 PM
Fronzizzle
08-09-2015 01:15 PM
Leggman1
08-06-2015 04:15 AM
Quick Reply: fan switch not working??
