91 Camaro RS overheat/blew radiator
Car: 1991 Camaro RS
Engine: 305 V8 TBI
heres my story. I need your help.
bought a used camaro. I knew it had cooling problems. sometimes the car temp would raise but i would fiddle with the heat and a/c and it would go away. one day, im not paying attention to my gauges, the temp got to high and blew a hole in the top of the radiator. (pictured) anyways, now I have a car without a radiator and some sort of cooling problem. I'm no expert, but what I'm starting on doing to fix this problem is replacing the radiator and the thermostat. also, the engine fan motor has been replaced.
what else can i do to make sure my car stays nice and cool?
Engine: gone
Transmission: gone
Axle/Gears: gone
Re: 91 Camaro RS overheat/blew radiator
well change the radiator, thermostat as planned. fill with coolant and see how it does. make sure you have the air dam on the bottom of the car. that is critical to cooling on the third gens. if the fan comes on. and those other two parts are new. the only other culprit is the water pump. good way to check that is to see if the coolant level goes down radiator cap off when you rev up the engine. be careful playing with hot cooling systems. the fans may be coming on late also which could cause a getting hot condition. and of course good luck!
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
If the only time your fan comes on is when you turn on the AC, then your fan is good, the relay is good, but the fan switch is not, assuming you have the V8 TBI engine. Let it sit idling in the driveway or somewhere like that and let it warm up idling and see when the fan comes on, but watch the temp gauge and turn on the fan before it hits the red zone
Car: 1991 Camaro RS
Engine: 305 V8 TBI
1992 Trans Am
05-10-2023 07:19 PM
eightsixseven
08-14-2015 03:09 PM
Zachattack0925
08-12-2015 09:54 PM
Zachattack0925
08-12-2015 09:52 PM
