170 stat
Car: 90 IROC 2-92 Zs blk vert & prpl
Engine: stealth ram brodix track 1 ful port
Transmission: 700r4 4l80e
Axle/Gears: iroc 375 lokr 92 Z 277 pos vert 327
170 stat
Does anyone know where to get a 170 high flowing stat? Spring is here in Arkansas and it gets Africa hot and I can't find anything but 195 and a few 180 stats here but 170 is supposed to be the best all around and I can't find one. Some are supposed to be high flowing but that may be a marketing gimmick. Thanks in advance.
Car: 87' IROC
Re: 170 stat
Lower temperature thermostats don't improve cooling. They only set the minimum temperature the engine can maintain at steady state. If the rest of the cooling system isn't up to the task of maintaining the engine at 170, it'll keep climbing anyway. If your engine gets hotter than 195 now, its not the thermostat's fault.
The best way to get the engine to run cooler is to turn the fans on sooner.
Car: 1987 Black IROC-Z (SOLD)
Re: 170 stat
Re: 170 stat
I have a be cool radiator and a low temp fan switch but the car is not complete yet. I have to get a chip burned for it and I have heard that a 170 is the best for performance and still have a heater. So when I can find someone to do me chip for my 92 Z convertible I want it for a 355ci, 30lb injectors, holley stealth ram, brodix heads, all forged internals, 2210 headers, 700r4, 327 gears and a cam I haven't decided on yet. It shouldnt run hot with the good radiator and a chip made for 170. I want a good street driveable cam like a lt4 hot cam or a little bigger but chip friendly.
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Re: 170 stat
[funny haha how many times I have posted this link today, along with my exhaust one]
180...sweet spot
http://www.carnut.com/ramblin/_cool3.html
[exhaust incase someone ask http://www.pontiacstreetperformance....p/exhaust.html
180...sweet spot
Car: 1989 SS
Engine: LT1+1500$ hooker exhaust
Axle/Gears: 3.42 bogger
Re: 170 stat
180...sweet spot
[exhaust incase someone ask http://www.pontiacstreetperformance..../exhaust.html]
180...sweet spot
Car: 1989 SS
1 Post
Car: '91 1LE
Engine: 377 w/Stealthram
Axle/Gears: 3.42 Torsen
Re: 170 stat
GM part# 10220957. It's $7.89 right now at www.gmpartsdirect.com. It's a 170* from a late model S10 Blazer I believe. I run these in my engine with a low temp fan switch and my engine runs at about 180-185. This thermostat will NOT have any effect on the ECM as stated elsewhere.
Re: 170 stat
With the air dam intact, every stock thirdgen I've owned has run around 180* on the factory gauge. The only time it goes higher is when the car is sitting idling at a stop, until the fans come on. Lowering the fan temp would fix that, but it's never been enough of an issue to me to make it a priority.
If you have an overheating problem, a lower temp thermostat isn't going to fix it. If you really want a 170* thermostat, there's a tech article, used to be a sticky (https://www.thirdgen.org/forums/cool...total-fan.html), with a GM part number for a 170* stat.
Guest
Posts: n/a
Re: 170 stat
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
Re: 170 stat
Stewart sells high-flow ones. I bought a high flow 160* for mine (carb).
Re: 170 stat
Hey just a Question. Whats a the normal operation temp for a 305? Reason being this is my first V8 haha, so i just want to know if its normal if the temp stays just a bit under the 220 mark? i still havent done a new thermostat or water pump i have the parts and will do it when i have day off of work.
Thanx
Thanx
88SS6SPEED
11-11-2015 07:05 AM
mcgarnicle
09-24-2015 07:18 PM
