correct air dam 83 trans am
Car: 83 Trans Am / 96 Jeep XJ
Engine: 355 / 4.0 I6
Transmission: TH350 / Auto
Axle/Gears: 3.23 10-bolt / 4wd
Re: correct air dam 83 trans am
Not sure what the side pieces are, but it looks like a camaro air dam to me. The T/A air dam is longer and skinnier.
While we're on the topic, my 83 Trans Am is also missing its air-dam. I think that I could bolt a camaro air dam on and it will work all the same. Will it work?
Car: 1984 ta slightly modified
Transmission: auto 350 w/reverse valve body
Axle/Gears: 410 ratio
firebirds have the longer air dam that goes side to side. not sure if the camaro will work, Made my own out of aluminum, cause I could not find the firebird air dam.
I know what the firebird air dams are, I just wanted to know if I could use a camaro air dam instead, because I cant find a firebird one for some reason.
Ghettobird52
07-05-2024 11:18 PM
1992 Trans Am
05-10-2023 07:19 PM
eightsixseven
08-14-2015 03:09 PM
