car overheats when the engine is driving at high rpms
Car: Camaro RS
Engine: 350 5.7 V8
Transmission: 4 Speed Automatic
as in up hill, when the rpms are high the temp goes up, but the problem is that i when i drive at high rpms on a level surface i don't get the same problem. i feel that its just lack of air when i am driving up hill, because if i drive down hill in the same heat and even at high rpms the car runs fine no major temp change.
any tips for me?
any tips for me?
Car: 86' IROC-Z....and 5 other 3rdgens
Engine: 383 hsr
Transmission: built 700r4
Axle/Gears: stock 3.23, 10bolt
Re: car overheats when the engine is driving at high rpms
do you still have the lower air dam that attaches to the bottom of the radiator core support?
Besides the air dam, Camaros (at least some) have a Baffle, Rad Air Lwr GM p/n 14107379. Check the following link, post #13.
https://www.thirdgen.org/forums/cool...-question.html
JamesC
JamesC
1 Post
Car: 1989 Chevy Camaro RS
Engine: L30 TBI 5.0L Vortec
Axle/Gears: Stock
any tips for me?
any tips for me?
