Anyone know where to get a lower radiator hose?
Car: 1991 Camaro Z28
Engine: 357, Canfield heads, solid roller,
Transmission: Upgraded 03 Cobra T56
Axle/Gears: 9" 3.50 gears and Detroit Locker
I've always had just a straight piece of rubber hose for the lower hose. I want to put on a molded rubber hose but cant find what I need. I need the same shape as the stock one, but I need both sides to be 1.75 for my aftermarket aluminum radiator. Anyone know if anyone makes this or do I need to just look at everything Auto Zone sells and try to find something that will work?
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Anyone know where to get a lower radiator hose?
Think I'd do like you said and talk the AZ person into just letting you go behind the counter to see what you can find. If you find something, save the receipt - then you'll know what to get next time.
Car: 85 TA TTA clone
Engine: 355sbc (turbo planned)
Axle/Gears: 9 bolt rear disk
If you cant find something that works this might be an option.
http://www.summitracing.com/parts/SUM-390124/
Hotrodboba400
12-10-2019 07:07 PM
IROCZDAVE (88-L98)
09-02-2015 08:49 AM
