unconnected tab on radiator? (pic inside)
Car: 1989 Chevorolet Iroc-z convertible
Engine: 383, holley terminator efi
Axle/Gears: stock 10 bolt w/ 3.73
A little background information, The car is a IROC-Z convertible. The previous owner put a 5.7 TPI from a corvette in it, and fans do not turn on and i am wondering if this tab, that has nothing connected to it, has to do with the fans not coming on. I have turned on the A/C and the passenger fan still didn't turn on and the relays in the car are in a different order. To remove the tab, it just pulls straight out and the tabs that hold it on broke off and i need to find another one to replace it. It is located on the driver's side of the car by the battery. It's circled in red in the Picture. Any help would be great!!
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
Re: unconnected tab on radiator? (pic inside)
Looks like a temp or coolant level sensor to me, but i have no idea if it was stock on the vette. Its not stock on the iroc though. The fans were run by a temp switch on the side of the block.
Car: 90 formula
Transmission: auto
ive had those on my radiators too. made the mistake of pulling it out once and let my coolant out 30 miles away from home.
Car: 91 Camaro RS
Its never a good idea to unplug any sort of fitting from a radiator unless youre prepared to loose coolant.
Car: 91 Camaro RS
Maybe, but I thought pulling plugs on radiators was obviously a bad idea....
i've purchased serval temp sensors that do not fit on my block would this jet fan switch work they open at the same temperature but one looks to have an adapter piece that comes with it.
http://www.summitracing.com/parts/HYP-4030/
or
http://www.summitracing.com/parts/HYP-4028/
or
Car: 91 Camaro RS
The temp sensor that came as part of my fan control module didnt fit my block either. Roughly $5 at pep boys for a couple of brass adapter fittings and it works fine.
1992 Trans Am
05-10-2023 07:19 PM
IROCZDAVE (88-L98)
09-02-2015 08:49 AM
Thirdgen89GTA
08-20-2015 03:11 PM
