Radiator fan
Radiator fan
Last week i noticed my car was running hotter then normal but not overheating. My radiator turns out had like 15 holes in it..so i replaced it. When everything was put back now my fan isn't working. Fuses and wiring all seem to be intact. Anyone have any suggestions what it might be?
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Fan Plan
Apply 12 volts directly to the fan.
If it runs remove the 12 volts you applied and ground the fan switch in the engine.
If it runs the switch went bad.
Happy Racing!
I Didn’t Wreck, The Track Moved
Happy Racing!
