87 5.7l gta ac problem
When I turn on the ac or heat I get strong air blowing thru defrost vents and after about a minute veeeeryyy minimal air thru normal vents almost not noticable unless I hold my hand on the vent. What do I have to do to resolve this and get my ac blowing. Will a recharge do it? I'm in florida and its gonna get hot again soon. Please help
Car: 1991 Z28 vert, 1988 GTA
Engine: 305 TPI, 305 Carb-finally runs!
Transmission: TH-700R4/BW WC T-5
Axle/Gears: 3.73 posi 4th gen 10-bolt/BW 9 bolt
Re: 87 5.7l gta ac problem
Does this car have the manual HVAC controls or the pushbutton HVAC controls? There is a little gasket on the controls themselves that route the vacuum to the different actuators for the doors, that piece gets dried out and shrivels then leaks vacuum, so even if your vac line off the intake is good you can still have a vac leak. there is a write-up somewhere on this site for fixing it, i need to do it to my car.
84z96L31vortec
08-20-2017 12:16 AM
84z96L31vortec
08-10-2015 08:27 PM
