Temperature gone up
Car: 1992 Camaro RS, 66 Mustang, 78 t/a
Engine: 5.0 TBI, 289, 400
Transmission: 700R4, C4, th350
Temperature gone up
Since yesterday, the coolant temperature has gone up maybe 5 degrees when on the highway, and too much around town. It used to stay at a constant 140 or so, but I have seen the needle move since. Around town, it is now at over 160. Coolant is full and I poured coolant in the tank. No leaks. It has new both coolant sensors, new antifreeze, thermostat replaced a couple years ago, but wasn't driven till later in the year. I just cleaned my air filter last night (was black).
1 Post
Car: 85' Trans Am !best car ever!
Engine: 305tpi 215hp LB9 two bolt,
Transmission: th-700r4
Axle/Gears: stock (3.27)
Re: Temperature gone up
stock t-stat is 195* average stock temperature is 225*. do you got a new prom/chip? thats cold. man.
I know it is, but I keep reading about people switch to 180.
anyway, I put a 170 thermostat in back when I thought those tbichips would do me good and haven't changed it since. I think it's weird how it suddenly goes up.
1 Post
its cold now. I installed i think a 180 t stat in may, because the old tstat stuck open and never closes. Now i got to get another one. same issue 6 months later. im going to do 180 again, different brand. i guess its better its stuck open then shut in my case.
it went back to "normal" after a coolant flush and then a intake gasket fix
