A/C brackets help needed
Old 07-13-2009 | 12:49 AM
OKCcamaro's Avatar
Car: 85 Z28
Engine: 305 Carb
When I rebuilt my 305 over a year ago I left off all the A/C equip since the compressor was locked up. I want to replace it now but can't remember how the brackets go back on. I know I should have took pictures but didn't. Does anyone have pictures of their carburated 305 with the compressor on the drivers side? I am going to cook. It's been 105deg the last two days. Please help!!
Old 07-13-2009 | 01:44 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Re: A/C brackets help needed
A helms manual or someone who can take a picture is going to be your bet bet.
You only other option is a dealer parts explosion like this one....
Attached Thumbnails A/C brackets help needed-accomp.gif
Old 07-13-2009 | 02:00 PM
Scorpner's Avatar
Car: 85 SC, 86 Berlinetta
Engine: V6, V8
Transmission: 700r4, 700r4
Lol, I did the same thing. I hope this helps. (I had to modify the image for everything to show up.)
Attached Thumbnails A/C brackets help needed-gray-i.jpg
Old 07-13-2009 | 06:07 PM
OKCcamaro's Avatar
Car: 85 Z28
Engine: 305 Carb
Thanks, just this little bit helps. I will look at it tonight after it drops below 100*.
Old 07-14-2009 | 11:50 AM
OKCcamaro's Avatar
Car: 85 Z28
Engine: 305 Carb
Thanks again, the pictures and diagram helped. I think I figured out the A/C brackets. Now I am not sure about the bottom bracket for the powersteering. I had to somewhat jerry rig it before without the A/C brackets being installed. Does anyone have a diagram or pictures with it?
Old 07-18-2009 | 09:27 PM
Mrgref92's Avatar
Car: 1986 Camaro Sport Coupe
Engine: L69
Transmission: 700-R4
Axle/Gears: 2.73's
Power Steering and A/C compressor
Attached Thumbnails A/C brackets help needed-100mbpicture.jpg   A/C brackets help needed-100mbpicture1.jpg   A/C brackets help needed-100mbpicture2.jpg
Old 07-18-2009 | 09:33 PM
Mrgref92's Avatar
Engine: L69
Axle/Gears: 2.73's
More pictures, Hope this helps
Attached Thumbnails A/C brackets help needed-100mbpicture3.jpg   A/C brackets help needed-100mbpicture4.jpg   A/C brackets help needed-100mbpicture5.jpg
IROCZ1989
01-24-2016 04:55 PM
kitt23
Exterior Parts Wanted
08-15-2015 01:37 PM
86camaroman201
Fabrication
08-11-2015 11:39 PM
GEmrsn
Interior Parts Wanted
08-08-2015 04:15 PM
