Replace Tranny cooler lines with Hose what fittings would be best?
1 Post
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
Hi
Will replace the steel lines with braided hose and wonder if I should go straight or 45deg fittings on the tranny?
On the cooler side I'll use one straight and one 90deg.
Will use 1/4 NPT to AN6 adapters on the tranny/cooler.
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Replace Tranny cooler lines with Hose what fittings would be best?
I think I used straight on mine.
Car: 84 camaro, 88 trans am, 98 camaro
Engine: Modded , stock, LSX modded
Transmission: 700r4, 700r4, t-56
Axle/Gears: 327, 308, 373
i used two 90*
two 45*s was a good angle. straight will probably work fine though. dont you have to use teflon lined hose for the trans lines?
Engine: 383 Carb
Transmission: 4L60
No, only for brake fluid.
Zachattack0925
08-12-2015 09:54 PM
Zachattack0925
08-12-2015 09:52 PM
