Water being forced out my resevior bottle
Car: 1988 Firebird Formula WS6
Engine: LO3 305 tbi
Transmission: 700 R4
Axle/Gears: 3gen housing zexel torsen posi 3.42
my car starting running alittle hotter than usuala few days ago. About 4 months ago i changed the t-stat i put a 180* in there, factory one was a 195*. I check over the whole engine compartment, no leaks, fan works, and radiator is only 1.5 years old. hoses don't collapse. is the t-stat my problem? or will i be needing a water pump? maybe both? i appreciate any help thnx alot guys.
-Rob R.
88 firebird formula ws6 5.0Ltbi 700r4
-Rob R.
Re: Water being forced out my resevior bottle
-Rob R.
-Rob R.
check the radiator cap. could be the problem.
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 1984 Camaro Z28
Engine: L69 305 H.O.
Put in a good quality T-Stat? or discount junk. I still go to the dealer for most parts. Just bought a $46.00 ACDELCO distributor cap and $10.00 rotor.
Car: 1989 GTA
Engine: SuperRam 350
Transmission: Pro Built S/S TH700R4
The only time I had coolant coming out the radiator overflow tank was when my headgasket was blown. But you'd notice other problems if it were that.
Radiator cap....I tried the el cheapo no name brand, but it leaked brand new. Got the GM cap from the dealer and it sealed up perfectly.
I'm guessing water pump.
Since this started happening after you changed the T-stat, did you maybe put it in upside down? You say the fan works. At what temp is it coming on and off?
Engine: LO3 305 tbi
check your radiator cap for what psi its rated at, you can take your radiator cap to a shop and they can test them, if its rated at 16 psi and doesn't hold then when the cooling system gains pressure it forces it in the overflow. another option is blown head gasket, whenever the car isrunning combustion chamber pressure enters the cooling system and puts excessive pressure in the cooling system and will force it out, might also check to make sure your cars cooling system is bled out, sometime when you fill them the cooling system gets airpockets in them and coolant won't flow properly,
Engine: LO3 305 tbi
