Radiator Fan not Working
took out the fan hooked it up to a battery and it ran...checked the fusses all fine.its just not kicking on...? it only runs when the air condition fan is on...single fan. not 2... any help??? thanks!
Re: Radiator Fan not Working
Check on the Fan Switch on the block. It should be on the passenger side, towards the back. Theres a wire running to it. Once the coolant hits a certain temperature, its grounds out the relay and the fan kicks on. So check for that green wire and you may need to replace that sensor.
1992 Trans Am
05-10-2023 07:19 PM
eightsixseven
08-14-2015 03:09 PM
