Willie's Total Fan Control - Project Over
First I would like to thank Willie for writing this up and taking the time to call me and help me finish some wiring for the Total Fan Control project on my car.
A big Thanks Willie!!!!!
I would like to share what I did inside with the toggle switches. I found a "project box" at Fry's Electronics that perfectly matches the color and texture of the dash paneling. The design of this panel fit right under perfectly. If I wanted to change something in the box, there are 6 small screws from the bottom that allows the cover to come off.
Then I cut to small holes for the fan leds. Fan 1 on top of Fan 2. The I added 5 wholes for the toggle switches (so I have one extra that I will be using for something else). Screwed the box to underneath as per the photo. Cut a notch in the back so I could run the wire from behind, and used split flex tubing to cover the wires. I finished off the toggle switches with black toggle switch covers. Then I labeled the switches with black background and yellow fonts labels to match the rest of the interrior, and thats is it. I'm pretty happy with the results. Take alook.
Thanks.
Oscar.
Thanks.
Oscar.
Car: 1988 Iroc
Engine: 383 TPI
Axle/Gears: BW 9 bolt 3.27
Re: Willie's Total Fan Control - Project Over
Oscar, looks real good! Nice match with the "project box".
Car: 1987 Firebird
Engine: 355
So what do they do? How do they work? Or maybe you could provide a link to willie's thread!
Looks really neat. My kind of mod. Looks like its factory.
Car: 92 RS(sold) 1989 IROC-Z
Axle/Gears: ones that turn
I have to agree I really like that box, I might have to get one of those to mount some switches on. I'm curious as to what total fan control is I remember reading about it awhile ago does it require that many switches?
Thanks for the compliments guys. Here's the link and the skinny on this. There's also a link to wiring instructions I need to find if you're interested in doing this.
https://www.thirdgen.org/cool
I did this becuase as we know, these cars run so frightenly hot, especially in street traffic and hot weather. This now gives me "total control" and peace of mind.
So basically I did the full mod as per Willie designed using the Hayden 3652 (fan 1) and 3647 (fan2). Only the switch box layout is what I chose to design. The nice thing is you can choose what you want to do or leave out. Do both fans or only one fan. As I said I did it all.
So on my switch box, I have 2 leds. They light up when the fan is in operation. If fan 1 is on the led (top led) lights up telling me it's on. Same for fan 2 (bottom led). The leds are not bright or annoying. Then there are the switches from left to right. The first one when on (up position) makes fan 1 come on when temperature reaches 185 degrees and off at 170*. When off it is back to stock. Switch 2 - is just a manual turn on switch at any temp (up position). Off position is back to stock. Switch 3 - turns fan 2 on at 195* (it's adjustable so you can set that at what ever you want). Off is back to stock. Switch 4 - just turns fan 2 on immediatly like switch 2. The last switch, 5 is just an extra switch not hooked up to anything yet. Will probably use it for my alarm. I have to say although this car only gets driven about 1K mile a year, I've always dreaded driving it during summer days and summer heat, in traffic or just left ideling. This way I can drive my car more with no worries.
So to summarize, if all switches are off (down position) the car is basically stock and the fans 1 and 2 come on at the temps they we're designed at by Chevy. Stock settings of course will help when going through smog. If you race, you can manually turn both fans to get the engine as cool as possible at the track. I did also do the 170* thermostat with holes drilled as per ******* instructions. Another note is that if you change thermostats twice a year, a cooler one in summer and a hotter one in winter, this eliminates this work, unless you enjoy doing that.
hope that helps!
p.s. this took time to do but was easy with some studying, reading, and ******* help, and I've never done electrical work before. So if I can do it any one can.
hope that helps!
Here the wiring instructions if your interested. Another member provided this in PDF.
https://www.thirdgen.org/forums/cool...n-control.html
Car: 87 Z28
Engine: 89 tpi soon tpis big mouth & tubes
Axle/Gears: 3:43
Very nice I'll have to build one also. But there isn't a frys for over 100 miles of me. I wouder if tandy (radio)shack has the boxes.
http://www.serpac.com/products_sl-07-s.htm
You can also try other searches and see if you find another box you may like.
pwdbychevy
04-16-2023 07:27 AM
IROCZDAVE (88-L98)
09-02-2015 08:43 AM
eightsixseven
08-14-2015 03:09 PM
