cooling fan run continuously from start up
Car: 84 firebird T/A
Engine: shinny 350
Transmission: slush box L65
Axle/Gears: round ones "3.73"
Does anyone know what would cause my cooling fan to start running when the engine starts and stay on continuously?
I just did a swap to TPI and there was no provision in the harness for a temperature switch like the carbed set up had in the block. the TPI set up only has a CTS and I thought that would control the fan?
any suggestions?
thx
Jeff
any suggestions?
thx
Jeff
Car: 1989 GTA
Engine: SuperRam 350
Transmission: Pro Built S/S TH700R4
Re: cooling fan run continuously from start up
One or two fans?
Is your A/C on? If so and you have 1 fan, it will never turn off. If you have two fans, at least one will never shut off. The other one will cycle on and off every so often.
Car: 1984 Trans Am
Engine: broken 385sbc
Transmission: G-Force rebuilt T-5
Axle/Gears: Currie 9" Ford 4.30:1
this is a problem?? i wired my fan to stay on with the ignition.. helps keep things cool.. most people have problems with it not coming on..
Car: 1984 Trans-Am WS6
Engine: WAS: 5.0HO, SOON: ZZ383-425HP.
Transmission: 700R4 with shift kit
You shouldent worry that it is on all the time, that is a bonus.
How did you hook the fan wiring up and did you disconect the switch in the passenger side head?
TPI cars have 2 fans. The above mentioned ac statement is correct. The wire that goes to the pass side head is also in the tpi harness, and is most likely grounded somehow if it did not do it before and ac isnt the issue. If its got a broken end and is grounded the fan will stay on when key is on. I would search down that wire first if you want it correct, then use any number of fixes for temp control mentioned by experts in this section,see sticky threads first.
I use a 170 T stat and a fan temp switch ( in the pass side head) that turn on fan at 189 instead of 220. I like the results.
Engine: shinny 350
my car was originally carburated. It is a 84 T/A with a single fan.
bout ten years ago I took the sensor out of the head all I have now is the sensor for the gage.
I bout a thermal switch that I am going to put in the block. Can I just connect the fan motor negative leg to that?
thx
jeff
thx
jeff
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
'I bout a thermal switch that I am going to put in the block. Can I just connect the fan motor negative leg to that?'
No, too much current for that guage wire. Run it through the stock relay on the driver's side firewall.
Car: 1991 camaro rs convertible
Engine: Built ls1
Axle/Gears: 3:42
From what everyone is saying about the electric fans and it being ok for them to run constantly,(talking about the single fan setups now), i dont agree. They were set up from the factory to go on at a designated temp that was read by the temp sensor in the block. the camaro cooling systems and electric fan systems arent the best, but the problem you will run into with the fan constantly running with the ignition on is your going to burn out the fan motor and then you wont have any fan, i know this because it happened to me and i almost overheated without realizing it. i would strongly suggest either setting up the fan so you can turn it on when you need it, set it up like it was from factory or get a pulley driven flex fan.
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Did you go from having A/C to not having A/C? If so, then there are two wires you need to permanently join to turn the damn fan off, and they run up one of the A/C pipes to a switch. If not, then you need to trigger the relay with a temp-controlled switch (after ungrounding the stock wire, of course).
theshackle
03-05-2017 06:37 PM
