FLEX-A-LITE DUAL FAN KIT
Car: 1991 Z-28
Engine: 383 / TPIS MINI RAM
Transmission: 700-R4
Axle/Gears: MOSER 9IN 3.89
Hi, Has anyone wired a flex-a-lite dual fan up to the stock factory wiring. I was just currious could this be done. I really dont know about using the adjustable unit that they sent with the kit. I would really like it to work like the factory set up, so I can adust the temp in the ECM and when I kick on the AC both fans would come on. And if I did use the stand alon unit they sent I dont like the idea of sticking a probe through my new Be cool radiator, has anyone done the probe in the hose trick, and if so how long and and did you have any coolant leakage. THANKS
Car: 1991 Z-28
Well has anyone used a dual flex-a-lite fan on there car, and if so are you happy with the way your controller worked out? Please advise if you think it cant be hooked up like I previousley discussed, im about to wire mine and would really like some input.....THANKS
Car: 88 GTA
Engine: 383
Transmission: 700 r
I have used both the in hose and the radiator probe controlers. The in hose one took 2 clamps and some electrical tape to seal it up. I prefer the core probe myself. It fits between the fins of an oem radiator just fine.
Car: 1989 Camaro RS
Engine: LT1 from '96 Corvette
Axle/Gears: 3.42 diff
Are you guys happy with the setup on the Flex-a-lite unit?
I am going to install a dual aftermarket unit with a probe in the radiator, and am curious if others have used it successfully.
Does it come with relays and some kind of electronic controller? I couldn't get a lot of info, even on their website.
1Aauto
Sponsored Vendors
09-02-2015 01:35 PM
IROCZDAVE (88-L98)
09-02-2015 08:49 AM
IROCZDAVE (88-L98)
09-02-2015 08:43 AM
