coolant mist spewing from heater vents...
Car: 1998 Volvo S70
Engine: B5254S Engine
Transmission: Automatic
Axle/Gears: It's a volvo?
Car fogs up whenever I use the heater, and I mean fogs up to the point where I can't see anything.
It reeks of coolant whenever the heater is on as well.
Could it be the heater core? Or Temperature sensor? Or what?
Car: 1988 Formula 350
Engine: L98 350 TPI
Transmission: 700-R4
I'm going to venture that your heater core is shot. Only way to know is pull everything out and inspect it.
Car: 1998 Volvo S70
actually the car goes up for sale mid next month.
I am going to let it become someone else's problem.
Car: 87 Camaro IROC
you know its very simple to replace the core...mayb a 2 hour job...only car i know where the dash doesnt have to be removed is the camaro and firebird. i replaced mine with a 7mm socket, some extentions and a 7mm wrench. thers an article in the tech centre on how to do it simply by taking off the dashboard and the passenger side lower dash.
