What's the best Electirc Water Pump?
Engine: 383 stroker
Transmission: turbo 350
I was wondering exactly what the best electric water pump out there. I was think about the CSI water pump. I only have a stock radiator and Be Cool radiator fan. I have a 383 and once it gets up towards 170 and once I turn it off it takes awhile to cool down. What would you recommend? It is a drag car by the way.
Car: 1987 Camaro
Engine: 406
Transmission: Powerglide
Axle/Gears: Moser 31 spline / 4.86
I use the Proform electric pump. JEGS High Performance - Proform Electric Water Pumps I have a stock radiator with this pump and a Proform fan. After a pass im sitting on 180. turn the car off let the pump and fan run for about 2 min and its down to 140.
Car: 92 Camaro Z28
I have the Summit Elec. Water pump, with a Powermaster lowermount Race Alternator, and manual steering. The only thing the motor runs is the Alternator. I'll see if I can find a picture..
Ray
Ray
Car: 92 Camaro Z28
there are alot of passenger side lower alternator mounts available.... More then dirvers side.
here's one: March Deluxe Series Billet Aluminum Alternator Brackets: MCH-22003 - summitracing.com
Ray
Ray
Car: 92Z28,91Z28,91Z281LE,95ZR-1,08Z06
Engine: 406, 350, 305, 350, 427
Transmission: auto, auto, 5-speed, 6spd, 6 spd
Axle/Gears: all stock
thanks,
Engine: 383 stroker
It is good to hear that the Proform pump is used by someone considering that is actually the pump I am thinking about.
evilstuie
01-09-2020 08:29 PM
