Heater Box ???
Car: 98 Camaro
Engine: 441ci LS7
Transmission: th350
Axle/Gears: 4:10's
Heater Box ???
I am building a street/strip Iroc. I am taking the A/C out and was wondering what is involved in changing the A/C heater box to a non A/C heater box
Is the heater core different?
Are the box holes the same that mounts it to the firewall?
anything else i should be worried about
thanks in advance
thanks in advance
Car: 88 firebird
Engine: 355
Transmission: t-5
Axle/Gears: 9 bolt 3.91
I don't have a/c in mine, and my a/c heater box is still there. You have to get a different blower motor, along with the non a/c box, and the heater core you have now will work. I should've already changed mine, to a non a/c box, it looks better, and gives you more room to install headers. You don't need it to have a functioning heating system.
Car: 98 Camaro
Engine: 441ci LS7
Transmission: th350
Axle/Gears: 4:10's
Thanks for the quick answer i am trying to keep this car as stock looking as possible. I wish my car still had heat and a gas tank but cant have it all in a racecar
again
again
1 Post
Car: 1989 GTA
Engine: 350TPI w/ Speed Density
Axle/Gears: Borg warner 3.27
Yep, its all the same basically. The only thing that I found was a pain in the butt was trying to wire the blower motor using the stock harness connectors. It deffinitely looks better in there than the darn A/C box.
Car: 86 Trans Am, 92 Firebird
Transmission: TKO600, T5
i just took my stock box, cut it down to 1" tall off the motor housing and fiberglassed it back together minus the top part, i think it looks good, only downside is i removed the fan speed sensor thing so the fan is now either on or off, but thats fine with me
