Multiple trans coolers ????
Engine: L98 350
Transmission: 700r-4
i have a new trans and currently a small trans cooler. i purchased a b&m plate trans cooler to replace the smaller cooler. i was wondering if there would be any problems with running both coolers or am i just causing more harm than help. thanks
Car: 91 B4C
you can run both coolers ok. But you should also run it through the cooler in the radiator. Most manufacturers recommend this because it helps the trans get up to operating temp faster as well as cooling the fluid down some.
Linson
08-21-2015 02:12 PM
