Thermostat modding question
Car: 87 Trans Am, 89 RX7
Engine: 350tpi,350carb
Transmission: T-5,t56
Axle/Gears: 3.42 Posi,4.11 posi
Breathment poseted a sticky on this forum and one of th categories of it is cooling system mods and inside that their is talk of putting 4 small holes in the thermostat to prevent hot pockets. I was wondering if anyone does this and is it worth it?
Car: 91RS, 91RS
Engine: 305TBI, 3.1MP
Transmission: WCT5, TH700
Originally posted by Stekman
Yes and sure.
Yes and sure.
Thanks,
Max
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
I've seen anywhere from 1 to 4 holes, usually 1/8" in diameter done. I personally drill one hole.
I drill the hole on the flat disk area, about 1/2 way between the sealing ring and the inner valve portion.
can someone maybe take a picture of a "modded" thermostat with the holes drilled in it?
Car: Yes...
Engine: Last time I checked...
Transmission: See "Engine"...
