Vents acting funny in my 92 Camaro
Car: 1986 Z28
Engine: 305ci
I got in the car today and turned on the AC.
It will only blow out the defrost vent by the windshield. So I turned the heat on and had the same issue. After checkign further, no matter waht selection I use for the vents, it only blows out the defrost vent.
Is there a cable that coul have come loose from the controls, or is it something else?
1 Post
Car: 91 RS
Engine: 305 Tbi (L03)
Defrost is the default setting for te ac system when there is no vacuum. It operates on vacuum. Either there is a problem with the vacuum line leading to the unit or there is somthing wrong with the switch itself.
Car: 1986 Z28
Engine: 305ci
So that brings me to a bad switch... Right?
Are there any vacuum connections under the hood I need to check?
Car: 1986 Z28
Engine: 305ci
Check for vacuum at the switch. If you get vacuum at the switch, the switch is probably faulth.
I am assuming the switch in the console.
it is normally almost always a broken vacuum line in the engine compartment.they use a real thin black plastic line that gets brittle and breaks from the heat.Look on the firewall for it going in near the heater controls somewhere,I forget where.Unless you have been messing with something 90+ percent of the time that is what it will be.
Car: 1986 Z28
Engine: 305ci
I finally had a chance to look under the hood. What I found was a broke rubber hose about 1 inch long...
This is where the hose was...
This is the actual broke hose...
This is the repair...
So far it seems to be working. Also, the rough idle in the car seems to be gone. I will follow up with any issues and such.
THANK YOU!!!!
THANK YOU!!!!
92camaroJoe
08-13-2015 06:07 AM
mustangman65_79
08-11-2015 03:17 PM
