Smell of coolant from vent air
Car: 1991 Z28 Convertible
Axle/Gears: 3.23 with Eaton posi
That about says it. Stinks up my car. No leaks identified anywhere. Been a while since flushing my coolant sytem.
I just had the same problem.Didn't seem to be leaking anywhere but when I took off the lower hush panel...green fluid everywhere.Change it before it turns into a gusher all over your carpeting.Just a matter of time before it happens.
Car: clapped out 84Z
Engine: 355 efi roller
Transmission: tremec TKO
Same exact problem. No leaks on the carpet, just a pinhole leak in the heater core. I wasn't sure because the last one in another car burst like a dam. I got a nice surprise last night when I dropped the kick panel.
Car: 1989 Firebird Formula
Engine: 305 T.B.I. (Vin tag "E" = LO3)
Transmission: THM-700-R4
Axle/Gears: 10 bolt posi 3.23
heh mine must of made a pool under that kick panel becaue one day i just noticed the corner of my floor mat was wet, i just simply wiped that off, but became curious as to what made it wet, and well, when i pulled up that mat, i had a nide little green lake waitng for me
IROCZDAVE (88-L98)
09-02-2015 08:43 AM
eightsixseven
08-14-2015 03:09 PM
