Boiling & overflowing resevoir tank when car shuts off?
Why does it boil and overflow out of the resevoir tank? The car isn't overheating at all. Normal running temperature. Is there too much water/coolant? Even when it was low it would do that. But not before I re-routed the return tube to the side of the radiator. There are no leaks at all where I put the hose at.
Maybe a bad radiator cap?
Car: 91 Camaro RS
Engine: 305 TBI
Axle/Gears: 2.73 Posi w/Disc
Mine went bad from years of opening/closing the radiator -- the rubber seals were not longer pliable and were leaking.
Car: 92' RS
Engine: 357
Transmission: TH350
Axle/Gears: 4.10
*sigh*
Glad to hear that b/c i heard through some other's that it could be a head gasket leak causing the it boil.
1992 Trans Am
05-10-2023 07:19 PM
theshackle
03-05-2017 06:37 PM
AkDrifted
08-17-2015 07:45 PM
