What Junkyard dual fan setup will work?
Car: 1986 Iroc
Engine: 454 Demon 850DP
Transmission: TH350, 3500 stall
I am looking for a more agressive dual fan setup for my Iroc. Has anyone found a junkyard setup that pulls way more air than our stock dual fan setup?
1 Post
Car: 89 formula
Engine: 383
Find a dodge intrepid it has a duel 2 speed fan with shroud it works much better then the stock duel fan.(Also check the eagel vision's they have them too. This is what the fans look like some fans may have larger motor on the passenger side but its the same thing
Hey E-man,
How did you wire your Ramchargers fan up and do you have any pics? I've been wanting to install mine but i couldn't find a connector for it, i didn't really want to cut my wires all to crap but i guess i might have to. I am also curious at to how you devised brackets or mounted it in the car.
Lucid
Lucid
1 Post
Car: 89 formula
Engine: 383
For the wiring I have a stand alone harness from here http://www.ronfrancis.com/ the connector I picked up at the junk yard.For mounting I cut the driverside bottom mount off to get the fan centered on the radiator and made the side brackets out of aluminum angle from home depot.The best way to explain it is with the brackets bolted to the fan it sit's on the frame rails.Also I made a custom radiator top support out of sheet metal that holds the fan at the top.I will try to get a pick
Terrell351
06-13-2021 01:13 PM
