Water pump leaking, can it be plugged???
Car: 1989 Trans Am GTA
Engine: 5.7 Liter
This morning when I got home, I noticed coolant pooling up around the tire. I looked under the hood, and there's coolant dripping from the bottom of the water pump. I was wondering if I could add Prestone stop leak to the radiator to fix things up, or am I going to have to just replace the pump when it gets to this point ?
Thanks.
Thanks.
Car: 1987 GTA
Transmission: 4L60e
I believe the water pumps on our cars consist of the pump and the associated gasket. Either one can cause leaks - and neither can be fixed with the stop-leak stuff. Correct me if I'm wrong - but the stop leak is for sealing small cracks in an alluminum radiator - not sealing leaks in gasket material.
Hope it helps 'ya.
Hope it helps 'ya.
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
There's actually a "weep hole" in the water pump that allows it to start leaking slowly when the bearings are worn enough to allow coolant past. The idea is to give you some warning before a catastrophic failure.
Could be your water pump going. When mine went it went bad. I just happened to have coolant with me and was close to my mechanic.
So I drove there monitoring my temp levels. Got there and he replaced the pump with some napa replacement.
evilstuie
01-09-2020 09:29 PM
eightsixseven
08-14-2015 04:09 PM
Zachattack0925
08-12-2015 10:54 PM
Zachattack0925
08-12-2015 10:52 PM
Street Lethal
08-12-2015 12:33 PM
