overcooling!
Car: 86 trans am
Engine: 305 tpi
Axle/Gears: 3.27 9 bolt posi
overcooling!
On the highway it runs about 140 to 160 and in traffic it runs about 200 to 220.
It has a 160 stat and aftermarket chip.
Is this normal or is there something wrong.
Car: N/A
Engine: Gen I 408
Transmission: N/A
Axle/Gears: N/A
my car likes to do that too, when cruising down the highway it likes to stay at what APPEARS to be 140*, but i've been told several times that the stock temp guage is nowhere near accurate enough and the temp is actually much higher than what it appears. its not a bad thing to actually run that cool you'll just use more gas.
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
Running too cool can hurt power too - especially on a carbed car. I had a 160 t-stat and electric fans running all the time in my camaro - it actually picked up about 15hp by putting in a 180 t-stat and setting the fans for 200 degrees. TPI cars are the opposite - the cooler, the better (within reason).
Car: 92' RS
Engine: 357
Transmission: TH350
Axle/Gears: 4.10
On a 730 ecm and datalogging, right before the "quarter" mark that you are talking about its about 160-170*. The temp gauges on our cars are an optical illusion. The quater mark to the 220* mark is only about 50* difference. The 100* mark (1st) to the quarter mark is about a 70* difference hence the thought of overcooling. I always thought mine was overcooling until i hooked up my datalogger and found out. Next time if you pay attention it takes alot longer to get from the 100* mark to the quarter mark then it does to get from the quarter mark to the half way mark.
*note* you also have to factor in rising momentum.
Check this post.........Overcooling?
