Water pumps keep breaking
Car: 89 Camaro RS
Engine: 350 carbed now
Transmission: World Class T5
Axle/Gears: Peg Leg w/ 3.73's
Alright for the past month I have been having some cooling problems with my car. All that is basically happening is that the car will run great and cool for about 10mins or so then after that the temp will get up to about 230 or so and I will shut it off. It will go all the way up to 250 if I let it its already happened once. So when the problem first started I replaced the water pump because it was making noises. When I replaced it everything seemed great and the problem went away, but then a week later the pump started making noises again and the problem came back. So I took it back to Oreileys and they gave me another and a week later same thing. I have now put 3 different pumps in this car and the current one is making noises and I still have my problem. Now what would make a water pump go out in a week? My air dam is working, I dont have a thermostat because the car runs coldest without one, and I have a mechanical temp gauge so I know its working. I appreciatte any help I can get guys.
Car: 89 Camaro RS
They start to make noise and my problem comes back. When The pump is new I wont have the problem at all, then the noise comes back and so does the problem, I know the noise is coming from the pump. So then I get the new one and the prob. goes away again for a while.
Car: 88 formula WS6
Engine: 305 Lo3
Transmission: 700-R4
Are you buying rebuilt pumps? or new? Might think about getting your money back and find another brand somewhere else!
First, check the bad one and see if your getting any wobble out of the pulley shaft and see if the bearing is bad. Might want to check your lower hose after warm up and see if it collapsing causing the pump to "run dry" for lack of coolant.
1 Post
Car: 91 Red Sled
Sounds like your belt might be putting too much tension on the bearings or it's offset which is then pushing (or pulling) the bearings in (or out) of the housing. With a really tight belt and mis-alignment you can go through waterpumps pretty fast. It's critical that you don't over tighten and that thigns line up.
Also be sure you're getting the right pump. Reverse rotation for the 1 belt setups, standard rotation for the v-belts.
Car: 89 Camaro RS
Car: 89 Camaro RS
1 Post
Car: 91 Red Sled
Hope that's your problem because if not that.... find yourself a better source for water pumps. I recommend Stewartcomponents.com . They're stage 2 pump is more than awesome but the stage 1 is still a good improvement over stock.
Car: 1986 Z28
Engine: 355TPI 380hp
Transmission: Rebuilt 700r w/ Transgo Shift Kit
One other thing that might help with the heat is a thermostat. Without one, the coolant isn't in the radiator long enough to cool down, so you're basically running hot coolant throught the motor all the time.
Just something else to think about.
Car: 89 Camaro RS
Ive been planning on getting a stewart pump, but I didnt want to pay $150 to find out the pumps not the prob. and then have it break again. Also on the thermostat thing, I tried several and for some reason this motor just runs cooler without one. Thanks for the help guys.
Car: 1990 350 tbi l98,
Engine: 5.7 tbi
Transmission: t5
You now that your engine has to reach a sertine temp so it can work right? You need a thermostat no matter what. you need to have that engine at a sertine temp.
1 Post
Car: 91 Red Sled
Anyways, also the whole no thermostat causes overheating is . I spend a year designing the cooling system on a mini-formula style open wheel racer. It has no fans and doesn't overheat even with 90hp, small radiators, and an average speed of 30mph. Basic thermo equations apply to any cooling system. Basically you can't flow too much coolant! With a heat-exchanger there are 2 fluids (or a gas in this case) air and water. Increasing either the air flow or the coolant flow rates will increase the temperature drop.
So if the air flow rate is the same, increasing the coolant rate (removed thermostat) will decrease the temperature of the engine (so long as everything is sized properly).
evilstuie
01-09-2020 08:29 PM
Chuck84TA
07-15-2016 09:05 PM
Zachattack0925
08-12-2015 09:54 PM
Zachattack0925
08-12-2015 09:52 PM
