FYI - ACDelco parts - Scam
This was new info to me, but after being burned somewhat on this I felt everyone needed to know.
I am rebuilding the A/C in my GTA. Trying to use all AC/Delco parts for the peace of mind. I bought a hose assembly, Compressor, and accumulator/drier. (Orifice will be a non AC/Delco - Variable Orifice). Anyhow, when I received the Drier from the local Advance Auto, I opened the AC/DELCO box and noticed right off that the drier didn't look "factory" wrong shape and poor welding when put together. Looked on the bottom and the part number stamped on the drier was a Four Seasons/Murray/Factory Air (all made by the same company) drier and the number didn't match the GM number on the box. I started acuzing Advance Auto of swaping parts. They ordered another one.. Same story. So I told them to give my money back. If I wanted a cheap Four Seasons, I would save the $20 and buy it.
Finally, I went to gmpartsdirect and today I get another Four Seasons/... style accumulator in their AC/DElCO box. So basically, I gave GM $51 for a $30 accumulator that I couldv'e bought anywhere. Talk about a rip-off!! Well, I am now stuck with it because all the shipping money lost. Gmpartsdirect and Advance both said that AC/DELCO is getting parts from other companies and sticking their name on it.
Long story short. GM parts - AC/DELCO no longer stands for higher quality. It stands for a middleman who buys parts from cheaper companys and sells it to you for a markup. Please be careful buying AC/DELCO - GM parts. Now, the hose assembly and compressor did have the AC/DELCO part numbers so I only presume they made them. Thanks for your time.. Pat
Originally posted by Jed
Funny...last wekend at Autozone I discovered that AC Delco oil filters are absolutely identical to STP oil filters.
I just got all the A/C stuff for an R-134a conversion, still waiting on hoses though. My compressor was labeled Delphi. Delphi makes stuff for Delco. I got my stuff through Jason Cromer. FWIW, I only buy from Jason Cromer or the famous Dal. I've bought a few things from P&G (partszoneonline.com), but their prices don't include shipping, so they suck.
91z
Have you looked at your accumulator yet?
My AC Compressor was Delphi. The Hose assembly had an actual Delco sticker, but the most visible part - the accumulator sucks..
Pat
Pat
No, not yet. I'm going to wait for the hoses, and some o-rings, before I begin assembly. I have to pick up some PAG oil and the conversion kit for the fittings too.
Edit: my accumulator is AC Delco too. No stickers on it or anything, it came in an AC Delco box with the part number on it. It's brand new.
Guest
Posts: n/a
-=FYI=-
R-414a is the substitute for R-12 no need to swap out any other other then the oil in the compresser R-414a can not be used with PAG (polyalkaleneglycol) oil i work in a HVAC place and i sell it all the time to replace R-12 but if you want i can get you 30lbs of R-12 for $2,000 thats the about the retail cost of R-12 now
Tell me more about R-414a. Is it cheaper than R-134a? I have these new parts, should I just use mineral oil in the compressor? Is R-414a a long term solution, meaning will it stay, or will a conversion be inevitable?
Guest
Posts: n/a
well i talked to some of the server guys that buy the stuff and they just put it in there car with out putting new oil in the compresser and it runs just fine. one guy told me that he has to put it in and your done never need to rechare it. unless you have a leck. the only problem is that you have to be certified to get it
Guest
Posts: n/a
Thanks for the info! It's good to come across an HVAC guy!
Do you know the price difference between r-134a and r-414a? I'm just curious because I was quoted $275 (locally) to recharge my freon system, and figured for that price and a couple hundred more I can get an r-134a system and fix my leaks.
Guest
Posts: n/a
well 30lbs (by far way to much for a car) is $105 for 134a and $400 for 25lbs of 414a BUT list to this... they sell R414a in 9.6oz cans for $15 and you only need about two cans for your looking at like like $30 for the 414a just what you need for a car. :-D
91Z - I would stick with 134A since you are redoing all the parts including hoses. 1) 134 can be bought at Wal-Mart and everywhere else, 2) Using anything but 134 and 12 will void the warranty (though I don't know how they can tell).
I am going to flush my evaporator and condensor. Then put on the new hose assembly, variable orifice (better than the stock apparently), drier, compressor, and the green o'rings with the Nylog oil. I have been told that this setup will work well. And if I can make another suggestion PAG oil hates the old Mineral Oil if the two get together. Use Ester 100.. But that's just my .02 cents.
Guess you were able to get an actual ACDelco Drier. This factory air drier has a square top instead of the rounded top. You were lucky..:hail:
Pat
Pat
Car: 1989 C4
Axle/Gears: 307
I agree with Red88. If your changing all the parts theres no need to worry about R134 leaking out. GM car's tend to leak out of the compresser so if its being changed I wouldent worry about it. If you really wanted to cool down swap a 4th gen condenser into your car, a used one will work fine. Now that ive got all the serpentine conversion stuff thats what Im doing. The last 134 conversion I did on a 3rdgen (not my own) only took 2 1/2 cans of 134 and a small can of oil 8 oz. That blew out 40* air on a 89* day even with the old r12 condenser. Much better and cheaper then R-12. Just remember to pull vaccum on your system and see if it hold for 15 minutes before charging.
Edit: Just read the tech article again, and it said to use PAG if mixing, ester if not.
91Z -
That's the $100 question about which oil to use. I read around and they also say Ester is a better oil and since the system will be thoroughly flushed, why not. But anyhow, one of the A/C retrofit sites, or one of these threads, or when I was reading the GM policy, they said to use Ester 100. You might want to look around I can't remember. P
1 Post
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
where can we get the OEM round top accumulators? i've looked @ ackits.com accumulators for our cars. they look just like the stock one. i'll probably get one from them in the future when i redo my A/C. if anyone is in need of one,(and hates those square/pentagon shaped ones) get one from there and let us know if they look just like on their website. they are listed @ 34.51
ACKits.com
see...
ACKits.com
see...
1 Post
Car: 1988 IROC-Z
not really round, but roundish. the shape of the cylinder is what i'm referring to. the replacement ones from autozone etc... are shaped like a pentagon on the top section of the dryer. opposed to the stock on which is shaped like the pic i posted. roundish on the top section of the dryer.
1 Post
Car: "02 z-28
Engine: LS-1
Re: FYI - ACDelco parts - Scam
1 Post
Car: 1988 IROC-Z
Originally posted by breathment
so this would be one of the ones yall are talking about as being non GM? (sorry just kinda confused)
yes that is the evil dryer we speak of. the non-stock one.
Yeah and there's a reason why "delco" parts are harder to find now.. A lot of the smaller auto parts stores have stopped carrying them. Less headaches for the auto parts stores. Autozone is a **** shop so it doesn't count as a parts store ;P
1 Post
Car: 1988 IROC-Z
hehe. AUTOZONE should be renamed RICEZONE. i'm guessing the old design found on our cars is the harrison design, while the new one is the delphi design.
Car: '86 T/A
Engine: 350/LT1 Intake
Transmission: 700R4 - Built
Axle/Gears: 4th gen 3.42
SSC
Haven't thought of this. Is a 4th gen Condenser a direct bolt in? How much fabrication?
Pat
SSC
Pat
Sonar
Guess we are both tired of the east Texas heat! I am at the same point with my rebuild and pulled the condenser yesterday in about 10 minutes. Figure it will help on the flushing and not make such a mess. (My GTA is not a daily driver)
It appears a 4th Gen Condenser would fit in there, just that the fittings are at the wrong spots requiring some fabrication of lines.. Maybe someone will have an idea on your thread you started.
According to the info on that Variable Orifice, they make it sound like the 134a conversion is going to be plenty cool.!? Pat
1 Post
Car: 1988 IROC-Z
take a look at what is now available to replace the fourseasons crap..... and @ your local autozone. the stuff is so new the barcode scan did not work(had to type the numbers in). they haven't been entered into the system over here.
this is the new stuff that replaces the the old factory air (four seasons) junk. the accumulator is the "old" design that came on our cars stock 10yrs ago. the compressor looks great. looks just the original one i had on there before i put the FS compressor. if you bought a four seasons you know what i mean. no ugly fourseasons deformed clutch. i will let you know how this stuff works out.
Compressor - Alma Compressor (repalces 57238)
Accumulator - Atco #7-5030 (replaces 33198)
Just want to add something about refigerants (also in the HVAC business). I used HotShot (R414b) in my car, which will directly replace r12, r134a, AND r500. Its pressure is about the same (+3 or 4 psi) as r12, so you don't need to change any hoses, and the fittings are the same as well.
My A/C hadn't worked since I bought the car last year, so I finally pulled a vaccuum on the system earlier this week and miraculously it didn't have any leaks. Charged it up with HotShot and it runs great. Sorry I don't have any costs on this, I got the stuff for free as extra, open inventory. But look around for it if you still have an r12 system.
Car: 1999 grand prix 3800/1996 chev. blazer Lt
Engine: 3800 V6
Transmission: automatic 4 speed
ACDelco - LOOK before you buy
i recently came accross a similar situation. i walked into a UAP NAPA parts store to buy spark plugs for my car. not sure of the part number but, sure i wanted an ACDelco OEM part. i asked the clerk if there was a big difference in preformance between the OEM part and other after-market parts available. i could not believe his response! he actually told me that i might find "NGK" stamped on the ACDelco spark plug! i asked him what he ment, and he informed me that ACDelco is starting to use OTHER manufactures products and putting THEIR NAME on them!!! So, BEWARE. that ACDelco OEM part you think you are buying may not be the Genuine deal. Check the numbers, and the manufactures. you could be buying an After-market part possing as an OEM. By the way, NO NGK's on the plugs i bought. they are PURE ACDelco and work great!
Guest
Posts: n/a
Re: ACDelco - LOOK before you buy
Car: 1988 Trans Am GTA
Engine: 5.7 TPI (Now HSR)
Transmission: 700R4 by Probuilt
Axle/Gears: 3:27 9 Bolt Posi W/ Discs
I dont know if this helps but I know that GMs contract with Delphi is up so yes they may be using different companies forthier parts now, I know this is true on new cars being built and if you dont beleive e look at a cobalt up close once.
LT1Formula
20
11-14-2015 12:02 AM
1989formula5.7l
08-15-2015 11:35 AM
57238, ac, acdelco, compressor, compressors, delco, ester, junk, made, mexico, murry, parts, partszoneonline, problems, scam
