Heat/AC Removal, Vacuum Lines?
I own a '88 Camaro IROC-Z. I am in the middle of doing a 5.7TPI Swap, and no longer want heat in the car. I am removing the HeaterCore & A/C and all that junk to save weight...
What do I do with all the vacuum lines coming into the car? Just plug up every single one, or is there something simpler? I am in the middle fo doing it now, I got the dash & center console all removed today...
Has anyone ever done this before?
i can see about removing the a/c, i just did that..
but my car is a daily driver and i need the heater to work so i can defrost the window for the most part...
Car: 87 Buick GN
Engine: 3.8L (231 cid) V6
Transmission: 200-4R
Axle/Gears: 10 bolt G80/ 3.42
There should be 2 vacuum lines go to the back of the HVAC control head. I disconnected mine at the control head and at the vacuum source in the engine bay and pulled the lines through the firewall from the inside. I then plugged off the vacuum source in the engine bay. Pretty easy, but I reinstalled it because I needed my heater back.
What else does the vacuum lines control on a TPI Engine? I know it controles my cruise, but does the enigne require any vacuum?
Where is the control head located on a TPI Engine?
Car: 87 Buick GN
The control head I was referring to is just the heater/ac control above the radio.
theshackle
03-05-2017 06:37 PM
mdtoren
08-16-2015 05:45 PM
