boiling antifreeze...
Car: 1986/88 Frankenstein Trans Am
Engine: carbed L98
quick summary of what happened:
so we had like 4 inches when i got out of school, i drove home n got stuck in front of my house for like 10 minutes. im reving the engine but i go nowhere. then all of a sudden i see green **** all over the street
pull off to the side open the hood
my anti freeze is BOILING
literally, it was bubbling and spewing out
edit: there is no cap on the over flow tank for the anti freeze
how can i fix this?
how can i fix this?
Engine: carbed L98
anyone? i bought a new thermostat with a gasket, but i looked where the therm is on the engine and it looks like a bitch to get out since like like 15F outside...DAMNIT
Engine: 305 TBI
Transmission: th700R4
my anti freeze only boils when my fan doesnt come on... was your tem high? when my temp would rise my fan would shut off then it would boil over.. if it was spewinginto your passenger side seat that might mean a bad heater core..
hope any of this helps check your air damn etc
sounds like you overheated some...
i would look to see if your fan(s) work, that would also be my first guess to look at, then work from there..
like when the last time your rad. cap has been changed..
also make sure you are running a decent coolant mixture like 50/50...
Engine: carbed L98
1 Post
Car: "02 z-28
Engine: LS-1
When you post it helps to have year, engine disp and type of fan system. Electric fan should trip on when the temp guage goes a little past the 220 mark on the guage. You can get an overflow tank cap at any parts store. Was the temp guage in the red zone? Could simply be the fact that it was overfilled assuming the guage was not pegged. Otherwise normal cooling system troubleshooting should resolve your problem. Boiling can be tricky because once the pressure is removed it blasts everywhere even if you are not overheating.
Engine: carbed L98
my car is a 88 trans am 350ci and im not sure what fan system it has yet. been real busy and havent had time to look everything over, i bought this car a wee ago. i hope i'll have time today to look at it.
i didnt look at the temp guage unfortunately
im going to replace the therm just in case anyway, just need time to do it
Sounds like you need a new radiator cap for starters! IF your coolant is boiling and spewing out, that's usually a sign that the radiator cap is bad. The cap keeps it under pressure. Water won't boil when it's under pressure. This lets it get over 212 degrees. The antifreeze raises that temperature some. Ever seen a pressure cooker? It keeps the water under pressure which lets it get hotter than 212 degrees. With no pressure, water won't get hotter than 212 degrees. It boils off and turns to steam. So, if your antifreeze is boiling, its not under pressure. Usually the radiator cap. You also need to get a cap for that reservoir. You can get those things at Auto Zone. Matt
Engine: carbed L98
alright so ill get a new rad cap, but how much pressure should i get? i also got a new thermostat, auto zone part 400-195. i dont know the temp on it, but i think its the same as the stock one. should i get a lower temp therm? thanks
The last three digits in that part number are the temp. It's a 195 degree thermostat. If you haven't opened that thermostat yet, take it back. Get one that's a 180 degree thermostat, and NOT an Auto Zone house brand thermostat. Buy the one that's a little more expensive. The one you have is probably fine, and it will work, but you might as well not skimp. Go with the 180 degree thermostat that's better quality than Auto Zone. I don't know how much pressure you should have in your radiator. As long as you have a good cap, it shouldn't boil. Matt
1 Post
Car: "02 z-28
Engine: LS-1
Look at the back of the stat on the brass side. It will be stamped usually with a number. If it says "STC" it is a Stant thermostat which is the OE supplier to GM. It will be fine to use and equivalent to a dealer replacement part. As far as temp is concerned 195 is the stock operating temp for the engine. It is fine to use. Radiator cap is an AC Delco RC-27 which is a 15psi unit. The Stant replacement is a 16psi cap, makes no difference as far as the 1 pound is concerned.
Engine: carbed L98
guys i did some work on my car today and it looks like it might be my head gasket that's causing all of this
i did a pressure test on my coolant system and the pressure went through the roof up the the 'danger' level in about 5 - 10 minutes.
i also seem to smell burned antifreeze
this could explain the missing antifreeze and why i have these problems after gunning the throttle a few times. thats when all this crap starts to happen.
can this be it? i hope not...
Engine: carbed L98
Originally posted by 25THRSS
Sounds like you figured it out. Head gaskets can be a bitch sometimes.
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
It's not hard to change the head gasket. I changed my first head gaskets 1.5 years ago when I changed heads while doing my carb to TPI swap. It will cost you less than $100 in parts.
If you work on it straight, shouldn't take more than 4 hours from start to finish. Just need to find a place to do it.
400195, antifreeze, auto, autozone, boil, boiling, brass, fluid, radiator, sounds, stant, stc, thermostat, underpressure, zone
