Little plastic bumpers on the side rail
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Anti rattle isolators to be exact. They're riveted to the side rail that holds the weather strip. Anyway, one of mine was broken off, finally decided to fix that.
Dr. side, all thats left.
What it looks like and a rubber clone i made.
Didint like the rubber piece (too soft). So i made a nylon one.
Mounted w/ rivet.
This where it tucks in. You can see just to the left where the rail was slamming into the frame when returning the top back on. Now for real world testing.
Mounted w/ rivet.
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Re: Little plastic bumpers on the side rail
8 and 1x here, but i think the rail is a separate piece from the part 8 rivets to.
Car: 1984 Trans AM
Transmission: 700-4r
I removed the egr valve as it had failed & replaced with a plate & gasket. Since u have a carb and it were my card I would remove all the tvs.
neilcase
02-15-2022 06:54 AM
redfirebirdman8
04-24-2007 01:56 PM
Crusader
Pacific Northwest Region
07-03-2001 02:56 PM
