tanneau release relay location
Old 05-24-2013 | 06:19 PM
sinkorskin's Avatar
An anyone tell me exactly where this is?
Old 05-26-2013 | 11:17 AM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
Re: tanneau release relay location
Below the center console, adjacent to the parking brake.
Lon
Old 05-29-2013 | 02:16 PM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
Is it the same as a coupe hatch release relay?
JOhn
Old 05-30-2013 | 09:07 AM
lonsal's Avatar
JOhn
Camaro yes. Firebird is behind the dash.
Lon
Old 05-30-2013 | 01:09 PM
okfoz's Avatar
Lon,
I must have not been clear... I was referring to the relay itself.
Do they use the same relay for the Convertible Tonneau release and the release on the coupes?
It would make sense as they do as they use the same button (more or less) just different graphic.
John
Old 05-31-2013 | 08:02 AM
tavert91's Avatar
Car: 91 Trans Am Convertible
Engine: LB9 5.0 TPI
Transmission: 5 SPD
Axle/Gears: Posi Rear
Is the Firebird tonneau relay on the inside of the firewall or the outside and approximately where is it (driver's or passenger side)? Thanks.
Old 05-31-2013 | 12:15 PM
okfoz's Avatar
I am trying to remember, but for some reason it is sticking in my head that it is behind the trim panel on the RH side... There is the relay for the power window, the subwoofer amp (thru 88) and If I remember a relay... Heck now I have to check...
Johnoooooo
09-22-2015 08:55 AM
Gunsbee
09-07-2015 07:10 PM
Jlanz55
09-06-2015 02:35 PM
tonys91rs
09-02-2015 07:07 PM
Quick Reply: tanneau release relay location
