1989 formula 350 vert
Car: 1989 Formula
Engine: l98
Planing on getting started on my vert finally! Since I saved this car from the crusher I was planning on doing all kind of mods to it but have decided to keep it stock.... Mostly thinking of 1le break upgrade up front with wonder bar and a 342 gear with a corvette l98 with all hi flow intake up top I also want to add top down solutions sub frames and do away with the external supports. Any thoughts just feel like talking about it I have all the parts but will need to rebuild the engine and tranny but that is the only hold up. Feel free to chime in. Thanks I could also do a ls6 t56 swap but was thinking that might hurt value. Thanks.
Car: 1990 irocz camaro
Engine: 350 tpi
Transmission: auto
Axle/Gears: 3.42 posi disc 10 bolt
Re: 1989 formula 350 vert
Its your car do as you feel ,your the one driving it ,its not about valve of the car its the love you put into it and enjoying the feeling of something fullfilling
Axle/Gears: 3.45, 3.27, 3.27
Lon
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
Was this Bill Speed's White Formula 350 Vert?
John
John
Engine: 4++,350 & 305 CIs
I'm not sure how far away I would stray from stock since it is a not often seen car.
It is your car and may do as you please but remember your more likely to get more coin for it stock than modded if you have to sell..
The side structures are rivited on and would leave a buttload of holes to fill and sealer to remove.
I have a light blue one with a dark blue top.
