Vert body twist?
Old 02-04-2013 | 03:30 PM
Stauf's Avatar
Car: 91 Z28 Coupe
Vert body twist?
The more I read the board, the more I worry. Last year I bought a 91 Z28 Vert with a 305 and T5. Well the engine took a crap, and I replaced it with a basic 350. I have a 650 carb and no other power adders. Do I have to worry about frame twist, or cracked windshield, if I decide to jump on the pedal? I haven't had any issues so far, but the car has been out of service for a while( for one reason or another). Should I look in to SFCs? What should I worry about?
Posted from Thirdgen.org App for Android
Old 02-04-2013 | 04:25 PM
mikesz1984's Avatar
Car: 1984 z28
Re: Vert body twist?
no matter what engine you have, sfc's are a must for any f-body, especially the verts. As for twisting it, when the frame is connected i dont think you will have an issue with a mild 350
Old 02-04-2013 | 11:48 PM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
SFCs are almost a requirement on a 'vert.
Old 02-04-2013 | 11:49 PM
yankeecarman's Avatar
Car: 1991 Trans Am convertible
Definitely. SFCS. Sphohn are good.
Old 02-23-2013 | 07:01 PM
zenish's Avatar
Car: 1989 camaro rs convertable
Engine: 305 tbi
Axle/Gears: 7.5"3.42 gears forth gen 2000 camar
http://www.google.com/imgres?imgurl=...QEwAg&dur=3671
this is what i have.i bolted them in and then had them welded.my cars stock except for the rear gear ratio.these and the front strut brace helped alot.
Old 02-23-2013 | 11:15 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
The carb swap worries me more than flexible chassis but subframes are a must have.
The car won't fall apart without them, unless its rusty.
Old 02-23-2013 | 11:51 PM
AutoRoc's Avatar
Engine: Vortec 4200 Inline 6 PT70 Turbo..
Transmission: 4L65E
They are a must.. These cars are flimsy! The body flexes more than the suspension.
If you are crafty I would suggest making a set, square/rectangular/round tubing...anything helps. Tie it to the front bolt on the rear LCA's. Somehow triangulate it over to the trans rails. Connecting it underneath the car with an overly beefy driveshaft loop.
My set were from Soutside Machine and are no longer produced but they do tie into the lca bolt. They are a rectangular tube design. Roughly 1.5"x2.5". My cage is welded to them through the floor, making it pretty damn stout.
Many wheels up launches so far, no wrinkled quarter panels. front door gaps have grown maybe 1/8" but nothing too bad.
Goodluck!
Old 02-24-2013 | 07:48 AM
Benc1's Avatar
Car: 1989 Iroc convertible
Axle/Gears: 3.08 posi
Goodluck!
You got pics of your sfc setup?
Old 02-24-2013 | 10:11 AM
BlueZee28's Avatar
Engine: Cammed 6.0L LSX
This. The carb swap makes me cringe.
You'll be fine with having a convertible, just put a set of SFC's on it like others have mentioned.
Old 03-03-2013 | 11:09 PM
njmick24's Avatar
Car: 92 TA VERT
Transmission: 5-SPEED
Axle/Gears: 3.08
What are the better sfc to get? I heard some of them had clearance issues. Are some better for single cats VS dual cats?
Old 03-03-2013 | 11:43 PM
Spohn are really good.
Old 03-14-2013 | 01:24 PM
Cadillac's Avatar
Car: '91 Firebird Convertible
Engine: 305 TBI (LO3)
Transmission: 700r4, Vette Servo
Axle/Gears: 3.27 9 Bolt, PBR disks
SFC's, Strust Tower Brace, and then a sterring brace... good to go.
Old 03-14-2013 | 06:38 PM
Mirror Image's Avatar
Car: 1991 Firebird convertible
Engine: LQ4 ls 6.0
Axle/Gears: 342 Limited slip
I have a lot of spohn to go on my car but I will be using bmr sfc they look better then the others
Old 04-05-2013 | 09:21 PM
POP6482's Avatar
Car: 1989 Iroc-Z Convertible
Engine: 6.0 LQ4 LSX
Axle/Gears: Moser 12 bolt w/4.11s
I used a set of BMR weld in SFC's. They fit great and didnt have any problems with install.
Old 04-06-2013 | 09:50 AM
abray1's Avatar
Car: 90 IROC 2-92 Zs blk vert & prpl
Engine: stealth ram brodix track 1 ful port
Transmission: 700r4 4l80e
Axle/Gears: iroc 375 lokr 92 Z 277 pos vert 327
My vert still has the stock 305 and I cracked the windshield going around some corners by my house. I have done suspension mods with bilstein shocks, red bushings everywhere, panhard and all other bars. also added a 327 posi 9 bolt with pbrs but I can attest to the masssive flexing of these cars but they handle pretty well.
Old 04-07-2013 | 08:44 AM
Cadillac's Avatar
Energy suspension bushings? I wish I never put those in. Sure the steering and front end are tight but the damn squeaking!!!
Old 04-08-2013 | 12:05 AM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
I've had Alston SFC's on my car for about 13 years. I've been selling them for a little over ten years. You really had me scratching my head with that picture in the link. Then I read the thread that was connected to the picture. What you showed is Alston's SFC's for a second Gen F-body, not their thirdgen F-body SFC's.
Check the picture of the thirgen version from my web site.
The "S"shaped one is the passenger-side and tucks above the catalytic converter. This style of SFC allows you the option of drilling and installing them yourself or to just have them welded on. The bolt holes give an extra location to weld them to the underside of the body.
I hope this helps clear up any questions.
Lon Salgren
Old 04-08-2013 | 12:34 PM
TTOP350's Avatar
Take the bushings out and clean that lube off that they give you.
Then coat it all with anti-sieze.
I drilled a set of them years ago for a grease zirt. It took awhile to get all thier sticky crap out but when it finally got all out they quit making noise.
Old 04-08-2013 | 02:09 PM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
I have found teflon paste is amazing for removing poly bushing squeak.
Old 04-08-2013 | 02:35 PM
BlackenedBird's Avatar
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
Originally Posted by lonsal
Lon Salgren
Alston's all the sway!
The Sphn/BMR/Whatever others kinds don't even connect to the rear subframe. They come close & attach to the rear LCA mount & do a decent job because that area is fairly stiff, but they do not connect to the actual rear subframe.
Old 04-08-2013 | 02:40 PM
carattini's Avatar
Car: Pontiac 89 GTA
Engine: 350 TPI 5.7L V8
it is a good Idea to get a subframe connectors because the body flex a lot and don't sound nice. that bean said I have a 89 GTA and beet the hell out of it and don't have any issues aside for the previus statement.
Hotrodboba400
12-10-2019 07:07 PM
Silver Spear
South East Region
18
12-04-2015 09:59 PM
83 Crossfire TA
09-08-2015 12:06 PM
Kenwood
09-04-2015 05:50 PM
Hotrodboba400
09-02-2015 07:28 PM
Quick Reply: Vert body twist?
