Powered top conversion?
1 Post
Car: 1989 camaro rs convertable
Engine: 305 tbi
Axle/Gears: 7.5"3.42 gears forth gen 2000 camar
Re: Powered top conversion?
concidering you have to help the top fold right manually i don't see how this will work.
Car: 88 iroc vert
yea, after doing a little more thinking, it would be more work than payoff.
seeing how you would have to get
the tonneou to lift
then the top come out
then make the bottom of the top lift up
tonneou down
bottom of top down
the tonneou to lift
tonneou down
bottom of top down
Location: Doghouse ······································ Car: 1989 Formula 350 Vert Engine: 350 L98 Transmission: 700R4 Axle/Gears: B&W 3.27
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
I think the things to overcome are these:
1) The obvious retraction of the top, I am not sure how different a 4th gen is from a 3rd gen, but it is obviously different.
2) The tonneau would be probably the trickiest part to incorporate. You have to release the top, fold the top upwards release the tonneau and then fold the top down. then lower the tonneau...
Somehow to have all this mechanically done with motors would be quite the engineering nightmare... If the top did not rest on the tonneau, I could see that being advantageous, but then again you would lose the look of the convertible as it was designed. You might redesign it so the top was more like a 4th gen, that did not have the Tonneau... That would probably be the easiest path, but that in itself would pose problems as you would need to make a replacement area for where the tonneau is now.
Lon
1992 Trans Am
05-10-2023 07:19 PM
ambainb
04-25-2016 09:21 PM
