Can the convertible frame be welded?
Car: 1987 GTA/ 89 Camaro Vert
Engine: 305 TPI/350 TPI
Transmission: 700r4/700r4
Axle/Gears: 3.27/3.08
I have a 89 Camaro and the main posts have snapped. I don't know if the frame is aluminum or white metal. Can someone tell me if it can be welded and if not what is the best route to get a new frame.
Engine: 4++,350 & 305 CIs
Re: Can the convertible frame be welded?
I'm not sure what part you need but I have a 89 camaro frame for parts.
Post a pic of what ya need and I'll see if I have it.
Car: 87 iroc-z & 88 vert
Engine: 350 tpi & 305 tpi
Transmission: 700r4 & tpi
Axle/Gears: stock & 308 posi
Yes the top frame can be welded I just did mine it is cast aluminum so it will have to be welded with Eaither a tig or a mig with a spool gun
Notta problem I literally just welded mine yesterday as long as you can line everything up it's no big deal
Axle/Gears: 3.45, 3.27, 3.27
I have several frames in stock. These cast frame pieces often break. I part out the frames specifically for instances such as this.
Lon
Lon
Car: 1997 K1500 SS/SB
Engine: LT1 with TPI on top
Transmission: 4L60E/np241,
Lon; would you possibly have the plastic caps that cover the rear door post where the seat belt comes up for a 91? also I need the trim that comes up the drivers rear post to cover the body joint
