sub box for a 88 vert
Car: 87 iroc-z & 88 vert
Engine: 350 tpi & 305 tpi
Transmission: 700r4 & tpi
Axle/Gears: stock & 308 posi
looking for pictures of a vert sub box anyone?
Re: sub box for a 88 vert
Are they the same as the hardtop well boxes or no?
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 91 Formula
Axle/Gears: 10 Bolt 3.23
Didn't look like the same style I usually see on the hardtops, plan on sorting some of the parts in the garage this weekend so we'll see.
ever find that box by any chance?
Engine: Cammed 6.0L LSX
Mine is pretty much a baffle board that sits on the ledge on each side of te trunk, and uses the bottom of the trunk as the rest of the "box".
Car: 91 Formula
Here you go:
![](http://www.mynetimages.com/4052781476.jpg)
![](http://www.mynetimages.com/100380d248.jpg)
Now that I've looked it over its not really vert specific however I've seen some sub boxes that have a good size lip that could possible extend into the top area. Now that I'm looking at it I really like the design, room to easily mount an amp and the cutout on the bottom right should have enough clearance to have the battery moved to the trunk and the box sit on top. I'll need to move the battery once I swap in the turbo drivetrain out of the Formula.
thanks for the pics it looks alot different then my coupe box and bluezee whered you get your board and btw your cars geourgous heres a picture of mine th_ff9db88b.jpg?t=1326831810
Where'd you guys get your boxes or boards I'm really lookin for one
Thanks, mine is just a piece of mdf or whatever it's called. It's what is used to make sub enclosures. It's cut to fit nice and snug. The subs are 10" dual voice coil Memphis Audio Power Reference Series, amp is a 1000watt Memphis Audio.
![Name: IMG_0184.jpg
Size: 64.9 KB](https://www.thirdgen.org/forums/attachments/convertibles/376750d1501393364-sub-box-88-vert-img_0184.jpg)
![Name: IMG_0185.jpg
Size: 44.4 KB](https://www.thirdgen.org/forums/attachments/convertibles/376751d1501393364-sub-box-88-vert-img_0185.jpg)
![Name: IMG_0186.jpg
Size: 68.0 KB](https://www.thirdgen.org/forums/attachments/convertibles/376752d1501393364-sub-box-88-vert-img_0186.jpg)
